[GRASS-user] v.select output vector is empty
Kevin Webb
kfw4 at cornell.edu
Wed Oct 29 11:49:02 EDT 2008
Greetings!
I am attempting to execute a "point-in-polygon" process on 2 vectors using
v.select and the output vector is empty, it contains no value/s.
When I create a map display of the 2 vectors I can clearly see the point
intersecting a polygon on the area layer, so it isn't an issue of
no-intersecting
values between the two datasets.
The point vector was created using:
cat /home/kfw4/dev/grass_db/one_point.txt | v.in.ascii out=single_point
fs=',' x=3 y=2 col='batch_id varchar(32),decimal_la double
precision,decimal_lo double precision' --o
v.info and db.select show the correct imported value:
GRASS 6.4.svn (lat_lon):~ > v.info single_point
| Layer: single_point
| Mapset: PERMANENT
| Database: /home/kfw4/dev/grass_db
| Title:
| Map scale: 1:1
| Map format: native
| Name of creator: kfw4
| Organization:
| Type of Map: vector (level: 2)
| Number of points: 1 Number of areas: 0
| Number of lines: 0 Number of islands: 0
| Number of boundaries: 0 Number of faces: 0
| Number of centroids: 0 Number of kernels: 0
| Map is 3D: No
| Number of dblinks: 1
| Projection: Latitude-Longitude
| N: 34:06:59.1408N S: 34:06:59.1408N
| E: 116:04:04.116W W: 116:04:04.116W
| Digitization threshold: 0
| Comments:
GRASS 6.4.svn (lat_lon):~ > db.select single_point
cat|batch_id|decimal_la|decimal_lo
1|BAT000000074|34.116428|-116.06781
The area vector was re-projected using v.proj:
v.proj PREC0101 location=PREC0101 mapset=PERMANENT
GRASS 6.4.svn (lat_lon):~ > v.info PREC0101
| Layer: PREC0101
| Mapset: PERMANENT
| Title:
| Map scale: 1:1
| Map format: native
| Organization:
| Source date: Wed Oct 29 09:15:47 2008
| Number of points: 0 Number of areas: 6720
| Number of lines: 0 Number of islands: 1212
| Number of boundaries: 13970 Number of faces: 0
| Map is 3D: No
| N: 49:25:31.535591N S: 24:27:48.66742N
| E: 66:54:50.339466W W: 124:46:59.356755W
| Comments:
Clearly, the single_point projection is contained by the PREC0101
projection. (Clearly?)
Yet, v.select yields nothing.
GRASS 6.4.svn (lat_lon):~ > v.select ainput=single_point binput=PREC0101
output=single_select op=overlap --overwrite --v
WARNING: Vector map <single_select> already exists and will be overwritten
Processing ainput lines ...
100%
Processing ainput areas ...
Writing attributes ...
Layer 1
v.select complete.
Building topology for vector map <single_select>...
0 primitives registered
0 vertices registered
0 areas built
0 isles built
Attaching islands:
Attaching centroids: Topology was built
Number of nodes : 0
Number of primitives: 0
Number of points : 0
Number of lines : 0
Number of centroids : 0
Number of areas : 0
Number of isles : 0
GRASS 6.4.svn (lat_lon):~ > v.db.select -c single_select
Any suggestions?
Thank you.
KFW
