[GRASS-user] v.select output vector is empty
Richard Chirgwin
rchirgwin at ozemail.com.au
Wed Oct 29 21:59:30 EDT 2008
grass-user-request at lists.osgeo.org wrote:
> Message: 1
> Date: Wed, 29 Oct 2008 11:49:02 -0400
> From: Kevin Webb <kfw4 at cornell.edu>
> Subject: [GRASS-user] v.select output vector is empty
> To: grass-user at lists.osgeo.org
> Message-ID:
> <6.2.1.2.2.20081029112204.032837f0 at postoffice7.mail.cornell.edu>
> Content-Type: text/plain; charset="us-ascii"; format=flowed
> Greetings!
> I am attempting to execute a "point-in-polygon" process on 2 vectors using
> v.select and the output vector is empty, it contains no value/s.
> When I create a map display of the 2 vectors I can clearly see the point
> intersecting a polygon on the area layer, so it isn't an issue of
> no-intersecting
> values between the two datasets.
> The point vector was created using:
> cat /home/kfw4/dev/grass_db/one_point.txt | v.in.ascii out=single_point
> fs=',' x=3 y=2 col='batch_id varchar(32),decimal_la double
> precision,decimal_lo double precision' --o
> v.info and db.select show the correct imported value:
> GRASS 6.4.svn (lat_lon):~ > v.info single_point
> | Layer: single_point
> | Mapset: PERMANENT
> | Location: lat_lon
> | Database: /home/kfw4/dev/grass_db
> | Title:
> | Map scale: 1:1
> | Map format: native
> | Name of creator: kfw4
> | Organization:
> | Type of Map: vector (level: 2)
> | Number of points: 1 Number of areas: 0
> | Number of lines: 0 Number of islands: 0
> | Number of boundaries: 0 Number of faces: 0
> | Number of centroids: 0 Number of kernels: 0
> | Map is 3D: No
> | Number of dblinks: 1
> | Projection: Latitude-Longitude
> | N: 34:06:59.1408N S: 34:06:59.1408N
> | E: 116:04:04.116W W: 116:04:04.116W
> | Digitization threshold: 0
> | Comments:
> GRASS 6.4.svn (lat_lon):~ > db.select single_point
> cat|batch_id|decimal_la|decimal_lo
> 1|BAT000000074|34.116428|-116.06781
> The area vector was re-projected using v.proj:
> v.proj PREC0101 location=PREC0101 mapset=PERMANENT
> GRASS 6.4.svn (lat_lon):~ > v.info PREC0101
> | Layer: PREC0101
> | Mapset: PERMANENT
> | Location: lat_lon
> | Title:
> | Map scale: 1:1
> | Map format: native
> | Organization:
> | Source date: Wed Oct 29 09:15:47 2008
> | Number of points: 0 Number of areas: 6720
> | Number of lines: 0 Number of islands: 1212
> | Number of boundaries: 13970 Number of faces: 0
> | Map is 3D: No
> | N: 49:25:31.535591N S: 24:27:48.66742N
> | E: 66:54:50.339466W W: 124:46:59.356755W
> | Comments:
> Clearly, the single_point projection is contained by the PREC0101
> projection. (Clearly?)
> Yet, v.select yields nothing.
> GRASS 6.4.svn (lat_lon):~ > v.select ainput=single_point binput=PREC0101
> output=single_select op=overlap --overwrite --v
> WARNING: Vector map <single_select> already exists and will be overwritten
> Processing ainput lines ...
> 100%
> Processing ainput areas ...
> Writing attributes ...
> Layer 1
> v.select complete.
> Building topology for vector map <single_select>...
> 0 primitives registered
> 0 vertices registered
> 0 areas built
> 0 isles built
> Attaching islands:
> Attaching centroids: Topology was built
> Number of nodes : 0
> Number of primitives: 0
> Number of points : 0
> Number of lines : 0
> Number of centroids : 0
> Number of areas : 0
> Number of isles : 0
> GRASS 6.4.svn (lat_lon):~ > v.db.select -c single_select
> Any suggestions?
> Thank you.
> KFW
Two thoughts.
1) Try telling Grass-GIS explicitly that ainput is a point and binput is
an area. I know these are supposed to be optional...
2) Use v.distance to see if the point's distance to the area is
calculated correctly (if the point is inside the area, distance should
be zero)
Richard Chirgwin
> Message: 2
> Date: Wed, 29 Oct 2008 13:46:29 -0400
> From: "Patton, Eric" <epatton at nrcan.gc.ca>
> Subject: RE: [GRASS-user] Tips for setting up an new
> FOSS-GEO-linux-box
> To: "Nikos Alexandris" <nikos.alexandris at felis.uni-freiburg.de>,
> "grass-user" <grass-user at lists.osgeo.org>
> Message-ID:
> <1715AFFECC318F4995A52EEE622FC30106385D at s0-ott-x4.nrn.nrcan.gc.ca>
> Content-Type: text/plain; charset="iso-8859-1"
>> OS:
>> OK, I think I shouldn't ask about which OS since foss runs on everything
>> (right?). But are I am curious to know if there are any advantages using
>> Debian instead of Ubuntu for example?
> Everyone has their own favorite; I've been using Ubuntu and Grass together
> since 2004, with no difficulties on 32-bit and 64-bit machines.
>> Filesystems:
>> Which filesystem is better(=safer/faster) for data storage? Is there any
>> important advantage to choose XFS for example rather than ext3?
> Not sure about the main differences/advantages of either; I've been using ext3
> since forever, with no regrets.
>> Partitions:
>> Do you keep your geo-data in a separate partition? I suppose yes. Have
>> you split further your partition based on other criteria, always related
>> with "working with geospatial data"?
> Pretty much the main 3-4 projects I'm working on are on /home, with anything I
> haven't worked on in the last 2-weeks backed up and archived on an external
> 2TB hardrive. (LaCie)
>> Do you keep all of your source code in a separate partition maybe?
> Nope, just under good old /usr/local. I only compile from scratch those applications where
> I need all the bleeding edge goodies and bug fixes, which, for me, is only Grass,
> gdal, and lilypond. I try to use the distribution's packages for everything else;
> makes it a lot easier to maintain using the package manager than chasing around
> and recompiling source for a ton of apps.
>> Organisation:
>> GRASS takes care to organise the data inside the GIS data-base and its
>> fantastic. But what about the "raw" data? How do you organise them?
>> Manually everything? Any tool to be more productive?
> Once raw data is imported into Grass, I usually get it off my hard drive and backed
> up onto something external, in case my computer melts down; then I can always
> rebuild from scratch. Of course the external drive could also melt down. I guess
> a RAID would be even better, but costs more.
>> BackUp:
>> How often do you backup your data? Do you just copy or do you compress
>> as well? What is safer?
> I've been using 'tar cjvf' for each project, but that is becoming unmanageable; I need
> to migrate to a versioning system as Dylan has done with rsync. At least for the
> projects I work on all the time. The old stuff can probably stay on the backup drive
> in tar.bz2 format.
>> Other:
>> Any other important issues when setting-up a new foss-geo-box?
> I just installed Ubuntu Intrepid 8.10 yesterday, and found it much easier
> installing packages via Synaptic rather than downloading the bleeding edge
> source packages and compiling. The only source package I had to compile was
> Grass.
> Thank you, Nikos
> P.S. Maybe we can add a new wiki-page if something useful comes out of
> this thread. Or maybe not... :-)
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
> Message: 3
> Date: Wed, 29 Oct 2008 20:29:23 +0100
> From: "Markus Neteler" <neteler at osgeo.org>
> Subject: Re: [GRASS-user] Tips for setting up an new
> FOSS-GEO-linux-box
> Cc: grass-user <grass-user at lists.osgeo.org>
> Message-ID:
> <86782b610810291229s4b92e79ch25713012075df505 at mail.gmail.com>
> Content-Type: text/plain; charset=ISO-8859-1
> On Wed, Oct 29, 2008 at 6:46 PM, Patton, Eric <epatton at nrcan.gc.ca> wrote:
>>> OS:
> Happy Mandriva user here :)
> Also Scientific Linux user on our cluster.
> I don't even install but run it directly with a link from
> grass64/dist.x86_64-unknown-linux-gnu/
> Markus
> Message: 4
> Date: Wed, 29 Oct 2008 20:34:59 +0100
> From: Nikos Alexandris <nikos.alexandris at felis.uni-freiburg.de>
> FOSS-GEO-linux-box
> To: grass-user <grass-user at lists.osgeo.org>
> Message-ID: <1225308899.14612.4.camel at vertical>
> On Wed, 2008-10-29 at 15:08 +0100, Nikos Alexandris wrote:
>> I know, I know... it's off the lists topic! But I need some help.
>> Probably I am going to "migrate" soon all of my stuff in a new
>> linux-box. So I would like to collect best practice tips concerning the
>> following:
>> OS:
>> Filesystems:
>> Partitions:
>> Organisation:
>> BackUp:
>> Other:
>> Thank you, Nikos
> Dylan, Eric and Markus,
> thank you for your precious time to respond.
> Since there are already 3 answers then maybe some wiki-page can be
> set-up out-of it. I'll try to structure the information a bit and open a
> page whenever I find some free-time (possibly this weekend).
> Please to all GRASS-users following the list, if you have some spare
> time and consider these questions important, participate with your
> ideas/tips/hints/tricks.
> Kind regards, Nikos
> Message: 5
> Date: Wed, 29 Oct 2008 21:03:56 +0000
> From: Glynn Clements <glynn at gclements.plus.com>
> Subject: Re: [GRASS-user] d.out.file now does GeoTIFFs
> To: hamish_b at yahoo.com
> Cc: grass list <grass-user at lists.osgeo.org>
> Message-ID: <18696.53180.114643.321976 at cerise.gclements.plus.com>
> Content-Type: text/plain; charset=us-ascii
> Hamish wrote:
>>>> Unfortunately 'd.info -g' is buggy, it reports exactly the same as
>>>> 'g.region -g'. But if that was fixed it would be an easy solution.
>> fixed in devbr6 but not trunk; I'm unsure about the changes needed.
> 7.0 doesn't have D_get_screen_window(); D_setup() uses R_get_window()
> instead (R_get_window() reports the raster clip region, which is
> initially set from $GRASS_FRAME).
> Also, I would suggest reporting the values returned from D_get_u_*
> rather than using the current region directly (which can always be
> obtained from g.region).
> Although the two should match, it's the values reported by D_get_u_*
> which are actually used, so using D_get_u_* would be more robust in
> the face of any future extensions (e.g. allowing the region to be
> enlarged to fit the window rather than shrinking the window to fit the
> region).
