Failure on Re: [GRASS-user] Help: Converting a raster map between
locations (from wgs84 lat / long to UTM)
Glynn Clements
glynn at gclements.plus.com
Thu Oct 30 17:22:43 EDT 2008
Corrado wrote:
> I have tried everything I could. I read the GRASS books chapters and the
> documentation. It does not work.
> The problem is that the files I have are in WGS84 unprojected. See here:
> http://www.worldclim.org/format.htm
> Whichever procedure I use, whther Daniel's or the book (for example: page 47),
> the problem is always the same.
> I create a location + mapset + map with the worldclim data (location01). I
> load the original data, and I call the raster map "precipitation". I generate
> the correct box with v.region and I call it "test". I create a new location +
> mapset (utm + osgb), called location02. I run v.proj in location B pointing
> at map "test"
> v.proj input=test location=location01 mapset=PERMANENT
> I have the same problem:
> PROJ_INFO file not found for location location01
> But of course the projection is not defined, the data are unprojected!
In this context, "lat/lon" is considered a projection. "unprojected"
or "X/Y" means that the coordinate system is entirely arbitrary (e.g.
pixel coordinates in an aerial photograph).
> I am slowly getting desperate .... I have been working on it several days and
> cannot get a sensible result. I have tried with different datum
> transformation parameters for osgb36 and trying to project .... but the
> results are very unreliable ....
> Do you know what should I do?
Use g.proj or g.setproj to set the projection information for
location01, choosing lat/lon WGS84.
