[GRASS-user] Re: GRASS-python-swig
g_massa at libero.it
Mon Sep 1 08:12:20 EDT 2008
thanks for the help,
maybe the solution will be useful: in "various Linux distributions are starting to ship with a version of the GNU C compiler which incorporates an extension which implements protection for stack-smashing". In that case the Makefile has to modified with
CFLAGS = -fno-stack-protector
gianluca
---------- Initial Header -----------
>From : "Hamish" hamish_b at yahoo.com
To : "g_massa at libero.it" g_massa at libero.it
Cc : grass-user at lists.osgeo.org
Date : Sat, 30 Aug 2008 23:33:16 -0700 (PDT)
Subject : Re: [GRASS-user] Re: GRASS-python-swig
> > I've still problems with GRASS/swig/python. I've
> > build python_grass6.py and _python_grass6.so with make
> > command in /swig/python directory and I copied the files in
> > /usr/lib/python2.5/lib-dynload.
> > If I import python_grass6 inside python I've this
> > message:
> > Traceback (most recent call last):
> > File "<pyshell#0>", line 1, in
> > <module>
> > File
> > "/usr/lib/python2.5/lib-dynload/python_grass6.py",
> > line 7, in <module>
> > import _python_grass6
> > ImportError:
> > /usr/lib/python2.5/lib-dynload/_python_grass6.so: undefined
> > symbol: __stack_chk_fail_local.
> did you run make clean after previous attempts? maybe it needs to be rebuilt from scratch.
> google found:
> http://ubuntuforums.org/showthread.php?t=352642
> Re: Compile glibc got error `__stack_chk_fail_local'
> "I had the same error.
> The reason: An already compiled xxx.o file which "uses" the __stack_chk_fail_local.
> This is the cause of not compiling the original xxx.cxx file due to performance.
> Solution: make clean
> and than make
> Hope this helps....
> PS: always make clean"
> which seems to support that theory.
> Hamish
