[GRASS-user] Print message before hitting "Run" in the g.parser UI
Luigi Ponti lponti at infinito.it
Mon Sep 1 17:20:22 EDT 2008
Hi there,
I have a bash script that processes a text file consisting of longitude
and latitude columns plus other columns with point data -- the script
imports the data and maps it. The script includes a parser-friendly
section so that the g.parser UI shows up if called with no arguments.
I would like to print info on the file such us the name of columns with
data (e.g. via g.message) so that the user can choose which one to
import. However, nothing can apparently be printed to the "Output -
GIS.m" window before the "Run" button of the g.parser UI is pressed (too
late for choosing a column...).
Does anybody see a way around this? Running native WinGRASS 6.3.0 on a
XP machine.
Regards,
Luigi
