[GRASS-user] BIN raster import
Richard Chirgwin
rchirgwin at ozemail.com.au
Wed Sep 3 21:44:29 EDT 2008
Hamish wrote:
> Richard wrote:
>> It would be nice if r.in.bin offered a "create new location" option.
>> That way, the import could work byte-by-byte without worrying about
>> bounds, and the user could georectify the imported raster
>> to their target location after import.
> wouldn't work, except if you sent the thing to a simple XY location.
> GRASS needs to know the map projection information before it can create
> a new location.
A simple xy was what I had in mind - just as I would use to import an
unreferenced image...
RC
> Binary files are just a long string of numbers. Without knowing the number
> of rows and columns it could be either wide and short or narrow and tall.
> There's no way for the module to pick that up otherwise. (unless like the
> old GMT format (r.in.bin -h) there is some header info in the file)
> If you know the rows and cols but are a bit fuzzy on what the bounds
> should be I would recommend importing it into the target location with
> south and west coords at 0 and north and east coords at number of rows
> and cols. Then you can run r.region (with a 'r.') at your leisure until
> r.info shows that the map resolution and bounds are ok.
> At least then you can see something on the screen and know that the
> other choices (byte swap, bytes per cell) are correct.
> note that GRASS considers the region bound coordinate to be at the
> outer edge of the border cells.
> Hamish
