[GRASS-user] supervised classification "no subgroup files
available"
Silvia Simoni
silvia.simoni at ing.unitn.it
Thu Sep 4 12:24:14 EDT 2008
> Thanks Markus!
> I'm now using grass6.4.svn but I still have trouble with the
> supervised classification process. Now I can run i.class and produce
> the spectral signature for my map but this file is NOT readable by
> i.maxlik. I get the following message: Can't read signature file
> [signaturefile].
> I checked in $MAPSET/group/subgroup/$SUBGROUP/sig/; the
> signaturefile is there but it only contains 3 lines, as follows:
> #comment
> single value XXXX
> Is this correct? I obtained other signature files from i.cluster
> which look different from this. It seems to me that i.class doesn't
> write the signature file correctly so that i.maxlik is not able to
> read it.
> How can I overcome this problem?
> thanks
> silvia
> On Sep 1, 2008, at 1:30 PM, Markus Neteler wrote:
>> Hi Silvia,
>> there have been a couple of fixes which probably didn't reach 6.3.0.
>> Could you try with 6.4.svn instead? There it will work.
>> Best
>> Markus
>> PS: See the list archives for older discussions on this.
>> On Mon, Sep 1, 2008 at 11:19 AM, Silvia Simoni
>> <silvia.simoni at ing.unitn.it> wrote:
>>> Hi grass-users,
>>> I'm trying to run a supervised reclassification for an orthophoto
>>> created
>>> using r.in.gdal and r.composite.
>>> Before running i.class, i run i.group to create a subgroup which
>>> is required
>>> by i.class. [The group containing 3 files .red, .green, .blue had
>>> been
>>> previously created during the import phase].
>>> When I run i.class the interactive screen cannot find the
>>> subgroup, it
>>> outputs: "no subgroup files available in current mapset". I get
>>> the same
>>> message also using i.gensig.
>>> I can see the folder and the file REF using "ls" in
>>> /Users/silvia/grassdata/location/mapset/group/subgroup/, but
>>> somehow GRASS
>>> 6.3 cannot.
>>> The result is the i.class exits.
>>> Does anyone know what's going on? How can I create a subgroup that
>>> GRASS 6.3
>>> can see?
>>> Thanks
>>> Silvia
>>> Silvia Simoni PhD
>>> DICA - Department of Civil and Environmental Engineering
>>> Universita' di Trento
>>> via Mesiano 77, 38100 Trento, ITALY
>>> tel. +39 0461 882610
>>> fax. +39 0461 882672
>>> e-mail: silvia.simoni at ing.unitn.it
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>> Open Source Geospatial Foundation
>> http://www.osgeo.org/
>> http://www.grassbook.org/
> Silvia Simoni PhD
Silvia Simoni PhD
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080904/62d8b65e/attachment.html
