[GRASS-user] BIN raster import
Richard Chirgwin
rchirgwin at ozemail.com.au
Fri Sep 5 17:42:27 EDT 2008
Hamish wrote:
> Richard Chirgwin wrote:
>> Returning to my original problem: is there a program for
>> Linux that will read a BIN DEM, and let me save it in something
>> like GeoTIFF, because I cannot beat the two-byte file size
>> error detected by r.in.bin.
> You can try gdal_translate, but I think if the numbers don't
> add up in r.in.bin then as a fundamental matter they won't add
> up anywhere else either. Unless GDAL's autodetect magic finds
> something special about the file format.
> Can you provide all the known info you can about the file?
> Exact filesize, expected dimensions, given bounds, endianness,
> bytes per cell, data type (floating point, integer, ..),
> expected data range, etc.? Maybe we can figure it out with a
> hand calculator.
I'll have to pick it up on Monday - the documentation is back at the
office! gdal_translate and gdalinfo don't recognise the file format ...
Cheers,
Richard
> It could be that there is some header info written before the
> stream of data which is padding the filesize by several bytes
> thus throwing off the sanity check math.
> Hamish
