[GRASS-user] create 3d plane from vector lines
    José María Michia
    jose.maria.michia at gmail.com
    Tue Sep  9 21:59:42 EDT 2008
Hi Carlos. You can use v.surf.rst. Description (from command help):
"Spatial approximation and topographic analysis from given ... isoline data
in vector format to floating point raster format using regularized spline
with tension."
Basic usage (remember to adjust region settings):
v.surf.rst input=contour layer=0 elev=surface
Where:
contour : name of the map containing your vector lines (iso lines or level
contours).
surface : name of the raster map, obtained from interpolation of the vector
lines.
More info here:
http://grass.itc.it/grass62/manuals/html62_user/v.surf.rst.html
I hope that this help you.
José
Saludos (sorry for my bad english)
2008/9/9 Carlos Guâno Grohmann <carlos.grohmann en gmail.com>
> Hi all,
> I'm stuck here, trying to create 3d vertical surfaces from 2d vector
> lines (to represent faults in nviz). hints?
> TIA
> Carlos
>  Carlos Henrique Grohmann - Guano
>  Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
> Linux User #89721 - carlos dot grohmann at gmail dot com
> _________________
> "Good morning, doctors. I have taken the liberty of removing Windows
> 95 from my hard drive."
> --The winning entry in a "What were HAL's first words" contest judged
> by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
> Can't stop the signal.
> grass-user mailing list
> grass-user en lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-user
------------ próxima parte ------------
Se ha borrado un adjunto en formato HTML...
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080909/fd9ebfbe/attachment-0001.html
