[GRASS-user] create 3d plane from vector lines
Carlos "Guâno" Grohmann
carlos.grohmann at gmail.com
Tue Sep 9 22:32:37 EDT 2008
Hello José.
v.surf.rst is not exactly what I want here, although I could duplicate
my vector lines with different elevations and then interpolate the
values to get _raster_ surfaces. I was thinking more in a v.extrude
way, just that it currently extrude areas to form facets or shifts
lines, but it doesn't create planes from line (AFAICT).
cheers
Carlos
On Tue, Sep 9, 2008 at 22:59, José María Michia
<jose.maria.michia at gmail.com> wrote:
> Hi Carlos. You can use v.surf.rst. Description (from command help):
> "Spatial approximation and topographic analysis from given ... isoline data
> in vector format to floating point raster format using regularized spline
> with tension."
> Basic usage (remember to adjust region settings):
> v.surf.rst input=contour layer=0 elev=surface
> Where:
> contour : name of the map containing your vector lines (iso lines or level
> contours).
> surface : name of the raster map, obtained from interpolation of the vector
> lines.
> More info here:
> http://grass.itc.it/grass62/manuals/html62_user/v.surf.rst.html
> I hope that this help you.
> José
> Saludos (sorry for my bad english)
> 2008/9/9 Carlos Guâno Grohmann <carlos.grohmann at gmail.com>
>> Hi all,
>> I'm stuck here, trying to create 3d vertical surfaces from 2d vector
>> lines (to represent faults in nviz). hints?
>> TIA
>> Carlos
>> Carlos Henrique Grohmann - Guano
>> Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
>> Linux User #89721 - carlos dot grohmann at gmail dot com
>> _________________
>> "Good morning, doctors. I have taken the liberty of removing Windows
>> 95 from my hard drive."
>> --The winning entry in a "What were HAL's first words" contest judged
>> by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
>> Can't stop the signal.
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
_________________
