[GRASS-user] Linking error in photo.2image
Hamish
hamish_b at yahoo.com
Fri Sep 12 21:29:58 EDT 2008
Craig Leat:
> > When running make in /grass6_devel/imagery/i.ortho.photo/photo.2image
> > I get a linking error as follows:
> > /usr/bin/ld: OBJ.i686-pc-linux-gnu/mark.o(.text+0x94a): unresolvable
> > R_386_32 relocation against symbol `line'
> > /usr/bin/ld: final link failed: Nonrepresentable section on output
> > collect2: ld returned 1 exit status
> > make: *** [/usr/local/src/grass6_devel/dist.i686-pc-linux-gnu/etc/photo.2image]
> > Error 1
Markus:
> I just found a similar problem in the GDAL list:
> http://lists.osgeo.org/pipermail/gdal-dev/2008-September/018278.html
> Maybe your problem in induced by the GDAL library?
After SVN update of the grass6 source I now get the same error when
compling photo.2image.
I reverted the only recent change (indent) but still get the error.
Nothing else on the machine has changed much since the last build,
maybe a newer version of GDAL from Debian backports.org?
This is Debian/Etch (stable) on i686.
gcc (GCC) 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)
Hamish
