[GRASS-user] v.trees.3d and gem
Gabriele N. gis.gn at libero.it
Sat Sep 13 14:00:40 EDT 2008
Hi all.
1)
I would like to install the module v.trees.3d of jackym Čepický (grass63
installed from binaries - ubuntu 8.04) but I did not understand how.
I downloaded gem but with the make:
root a gab-laptop:/usr/src/gem-1.03# make
gcc  -c at_exit_funcs.c -g -Wall -pedantic
-Werror-implicit-function-declaration -fno-common
In file included from at_exit_funcs.c:24:
globals.h:38:20: error: stdlib.h: No such file or directory
globals.h:39:19: error: stdio.h: No such file or directory
globals.h:40:19: error: errno.h: No such file or directory
globals.h:41:20: error: string.h: No such file or directory
globals.h:42:23: error: sys/types.h: No such file or directory
globals.h:43:22: error: sys/stat.h: No such file or directory
globals.h:44:20: error: unistd.h: No such file or directory
globals.h:45:20: error: dirent.h: No such file or directory
In file included from globals.h:49,
tools.h:39: error: expected ‘)’ before ‘*’ token
tools.h:43: error: expected declaration specifiers or ‘...’ before ‘FILE’
tools.h:45: error: expected declaration specifiers or ‘...’ before ‘FILE’
tools.h:47: error: expected declaration specifiers or ‘...’ before ‘FILE’
at_exit_funcs.c: In function ‘exit_tmp’:
at_exit_funcs.c:64: error: ‘DIR’ undeclared (first use in this function)
at_exit_funcs.c:64: error: (Each undeclared identifier is reported only once
at_exit_funcs.c:64: error: for each function it appears in.)
at_exit_funcs.c:64: error: ‘dir’ undeclared (first use in this function)
at_exit_funcs.c:67: error: implicit declaration of function ‘strcmp’
at_exit_funcs.c:76: error: implicit declaration of function ‘chdir’
at_exit_funcs.c:78: error: implicit declaration of function ‘sprintf’
at_exit_funcs.c:78: warning: incompatible implicit declaration of built-in
function ‘sprintf’
at_exit_funcs.c:81: error: implicit declaration of function ‘fprintf’
at_exit_funcs.c:81: warning: incompatible implicit declaration of built-in
function ‘fprintf’
at_exit_funcs.c:81: error: ‘stdout’ undeclared (first use in this function)
at_exit_funcs.c:83: error: implicit declaration of function ‘system’
at_exit_funcs.c:89: error: implicit declaration of function ‘opendir’
at_exit_funcs.c:90: error: ‘NULL’ undeclared (first use in this function)
at_exit_funcs.c: In function ‘exit_db’:
at_exit_funcs.c:112: warning: incompatible implicit declaration of built-in
function ‘fprintf’
at_exit_funcs.c:112: error: ‘stdout’ undeclared (first use in this function)
at_exit_funcs.c:116: warning: incompatible implicit declaration of built-in
function ‘sprintf’
at_exit_funcs.c:124: warning: incompatible implicit declaration of built-in
function ‘sprintf’
at_exit_funcs.c:132: warning: incompatible implicit declaration of built-in
function ‘sprintf’
at_exit_funcs.c:140: warning: incompatible implicit declaration of built-in
function ‘sprintf’
at_exit_funcs.c:148: warning: incompatible implicit declaration of built-in
function ‘sprintf’
at_exit_funcs.c:156: warning: incompatible implicit declaration of built-in
function ‘sprintf’
at_exit_funcs.c:164: warning: incompatible implicit declaration of built-in
function ‘sprintf’
at_exit_funcs.c:172: warning: incompatible implicit declaration of built-in
function ‘sprintf’
at_exit_funcs.c:181: warning: incompatible implicit declaration of built-in
function ‘sprintf’
at_exit_funcs.c: In function ‘exit_msg’:
at_exit_funcs.c:199: warning: incompatible implicit declaration of built-in
function ‘fprintf’
at_exit_funcs.c:199: error: ‘stdout’ undeclared (first use in this function)
at_exit_funcs.c:202: warning: incompatible implicit declaration of built-in
function ‘fprintf’
at_exit_funcs.c:205: warning: incompatible implicit declaration of built-in
function ‘fprintf’
make: *** [at_exit_funcs.o] Error 1
2)
I would also like to understand how to install addons, as v.trees.3d, where
GRASS is installed by source.
Thanks
Gabriele
View this message in context: http://www.nabble.com/v.trees.3d-and-gem-tp19473122p19473122.html
Sent from the Grass - Users mailing list archive at Nabble.com.
