[GRASS-user] error: too many nested evaluations
    G. Allegri
    giohappy at gmail.com
    Thu Sep 18 18:05:34 EDT 2008
I can't see any "*_modify" nor "update" inside progressbar.tcl
2008/9/18 Glynn Clements <glynn at gclements.plus.com>:
> G. Allegri wrote:
>> While importing a polygon with v.in.ogr I've received the following
>> message on the console:
>> too many nested evaluations (infinite loop?)
>>     (procedure "Gronsole::add_data_tag" line 1)
>>     invoked from within
>> "Gronsole::add_data_tag $path $ci out"
>>     (procedure "Gronsole::readout" line 13)
>>     invoked from within
>> "Gronsole::readout $path $ci $mark $fh"
>>     invoked from within
>> "if [eof $fh] {
>>                 Gronsole::readeof $path $ci $mark $fh
>>                 Gronsole::done_command $path $ci
>>         } else {
>>     (procedure "Gronsole::file_callback" line 2)
>>     invoked from within
>> "Gronsole::file_callback .gronsole.gronsole 41 cmdinsert41 file9"
>> and the process stalls...
>> This is the output until the crash:
>> http://www.geospatial.it/allegri/v.in.ogr_console.txt
> Try removing the "update" call from the end of ProgressBar::_modify,
> at the bottom of $GISBASE/bwidget/progressbar.tcl.
