[GRASS-user] v.to.rast shell script
John C. Tull
jctull at gmail.com
Fri Sep 19 22:07:21 EDT 2008
Hamish:
On Sep 19, 2008, at 6:45 PM, Hamish wrote:
> John Tull wrote:
>> I was wondering if anyone could suggest a simple shell script to
>> automate the process of running v.to.rast on all layers in
>> a single vector in GRASS?
> sure, just a bash for loop + g.mlist will do it:
> for MAP in `g.mlist vect` ; do
> echo v.to.rast in="$MAP" out="`echo $MAP | tr '[:lower:]'
> '[:upper:]'`"
> done
> in that example the other v.to.rast options would have to be
> constant of
> course.
> To avoid mistakes I like to capitalize a map name if it is going to be
> both a vector and raster map. Probably there is some simple sed
> command
> to just do the first character. otherwise just use "out=$MAP".
Thank you for your quick response. This, with the addition of
'type=vect' will give me a list of vectors, but I was wanting a list
of layers within a single vector. I am guessing there might be a way
to cajole v.info into doing this, but am not sure how at this point.
Thanks,
John
