[GRASS-user] v.to.rast shell script
John C. Tull
john.tull at wildnevada.org
Fri Sep 19 22:51:36 EDT 2008
On Sep 19, 2008, at 7:07 PM, John C. Tull wrote:
> Hamish:
> On Sep 19, 2008, at 6:45 PM, Hamish wrote:
>> John Tull wrote:
>>> I was wondering if anyone could suggest a simple shell script to
>>> automate the process of running v.to.rast on all layers in
>>> a single vector in GRASS?
>> sure, just a bash for loop + g.mlist will do it:
>> for MAP in `g.mlist vect` ; do
>> echo v.to.rast in="$MAP" out="`echo $MAP | tr '[:lower:]'
>> '[:upper:]'`"
>> done
>> in that example the other v.to.rast options would have to be
>> constant of
>> course.
>> To avoid mistakes I like to capitalize a map name if it is going to
>> be
>> both a vector and raster map. Probably there is some simple sed
>> command
>> to just do the first character. otherwise just use "out=$MAP".
> Thank you for your quick response. This, with the addition of
> 'type=vect' will give me a list of vectors, but I was wanting a list
> of layers within a single vector. I am guessing there might be a way
> to cajole v.info into doing this, but am not sure how at this point.
> Thanks,
> John
Ok, applying my little grey cells (as Poirot would say) to the problem
at hand, I believe I have resolved this as follows:
for LAYER in `v.category -g option=report in=vect | awk '{print $1}' |
uniq` ; do
v.to.rast in=vect layer="$LAYER" out=vect_$LAYER use=val
done
Hamish: thanks for the basis from which to suss the rest.
John
