[GRASS-user] Problems with OpenGL when compiling grass-6.4.0
on Mac OS X 10.5.4
Michael Barton
michael.barton at asu.edu
Sun Sep 21 12:28:52 EDT 2008
I'm now remembering that you discovered that we had to install the
iPhone SDK to solve this. Is this included in Xcode 3.1?
Michael
On Sep 21, 2008, at 8:58 AM, <grass-user-request at lists.osgeo.org> wrote:
> Date: Sun, 21 Sep 2008 10:58:27 -0500
> From: William Kyngesburye <woklist at kyngchaos.com>
> Subject: Re: [GRASS-user] Problems with OpenGL when compiling
> grass-6.4.0 on Mac OS X 10.5.4
> To: Elvis Dowson <elvis.dowson at mac.com>
> Cc: grass-user at lists.osgeo.org
> Message-ID: <91B049CD-7436-40E8-A90E-902DBCFB9C4D at kyngchaos.com>
> Content-Type: text/plain; charset=US-ASCII; format=flowed; delsp=yes
> On Sep 21, 2008, at 1:23 AM, Elvis Dowson wrote:
>> Hi Michael,
>> Thanks for the reply.
>> Could you please tell me what I should do to make it work with X11?
>> I am not
>> planning to use TclTk. I am planning to use vtk-5.2.0 and Qt-4.4.1.
>> What I need to do is to link grass-6.4.0 or 7.0.0 with X11 and then
>> get it
>> to work inside vtk-5.2.0. I will then try to use the QVTK plug in to
>> create
>> a vtkRenderingContext using Qt.
> Just a note: the TclTk GUI may be dropped in GRASS 7.
>> So far, I have managed to get vtk-5.2.0 and qt-4.4.1 compiled and
>> running.
>> I just have been stuck with getting any version of grass to compile
>> on Mac
>> OS X 10.5.4 using Xcode-3.1.1.
> Hmm, it should work without any patching.
>> X11 is broken on Leopard, it is impossible to compile programs
>> against it (more precisely whenever libGL is touched - directly or
>> indirectly). The easiest way to fix it is as follows:
>> cd /usr/X11/lib
>> sudo bash
>> # enter your password
>> mv libGL.dylib libGL.dylib.apple
>> ln -s /System/Library/Frameworks/OpenGL.framework/Libraries/
>> libGL.dylib .
>> This fixed the problem of ./configure being able to locate the
>> OpenGL libraries.
> I don't know where you came up with this - X11/OpenGL has always
> worked (with the exception of the broken linker in Xcode 3.0 which is
> fixed in 3.1).
> What is your configure command? Some things are supposed to be
> automatically detected, but being explicit can help. See the macosx/
> readme in the source for an example (much like Michael's configure).
> Sometimes you may need to give the OpenGL or X11 configure options
> some help.
> It's possible something is broken or misconfigured in your system. I
> hate to ask, but do you have Fink or MacPorts installed? These add to
> your shell PATH and may do other shell configurations that can
> silently cause trouble.
>> I have three copies of libGL.dylib. They are in the
>> following folders:
>> /usr/X11/lib
>> /Developer/SDKs/MacOSX10.5.sdk/System/Library/Frameworks/
>> OpenGL.framework/Versions/A/Libraries
>> /System/Library/Frameworks/OpenGL.framework/Libraries/Libraries
>> Which is the correct one?
> For X11, the X11 copy. The one in the SDK is just a duplicate of the
> system framework, and will be used automatically if you use the -
> isysroot flag. And in the end, X11 OpenGL gets much of its low-lewel
> functionality from the system framework. With disabling the X11
> OpenGL and symlinking the framework, as you did at the start, you lose
> the X11-specific functions, like glX.
> So, I'd say you should restore the original X11 OpenGL library, then
> figure out why configure can't find it. For configure errors, look in
> config.log for more detail why a test failed.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Those people who most want to rule people are, ipso-facto, those
> least suited to do it."
> - A rule of the universe, from the HitchHiker's Guide to the Galaxy
