[GRASS-user] Problems with OpenGL when compiling grass-6.4.0
on Mac OS X 10.5.4
Michael Barton
michael.barton at asu.edu
Sun Sep 21 16:10:04 EDT 2008
I don't know about compiling, but several of your environmental
settings will definitely cause problems if you try to run GRASS after
compiling for TclTk 8.5 aqua. See below.
Michael
On Sep 21, 2008, at 11:33 AM, <grass-user-request at lists.osgeo.org>
wrote:
> Date: Sun, 21 Sep 2008 21:20:06 +0400
> From: Elvis Dowson <elvis.dowson at mac.com>
> Subject: Re: [GRASS-user] Problems with OpenGL when compiling
> grass-6.4.0 on Mac OS X 10.5.4
> To: William Kyngesburye <kyngchaos at kyngchaos.com>
> Cc: grass-user at lists.osgeo.org
> Message-ID: <8F2F9B13-4C45-4119-A0A5-17CE4ECE0349 at mac.com>
> Content-Type: text/plain; charset=US-ASCII; format=flowed; delsp=yes
> Hi William,
> Upon looking more closely at the config.log
> configure:11340: gcc -o conftest -g -O2 conftest.c -lGL 1>&5
> ld: library not found for -lGL
> collect2: ld returned 1 exit status
> configure: failed program was:
> I see that ld could not find the GL libraries for some reason.
> However, I have put this in my .profile. The location I have put is
> usr/X11/lib . Is this the correct location?
> # environment variables
> export QTROOT=/usr/local/qt-4.4.1
> export GRASS_TCLSH=/usr/X11R6/bin/tclsh
I would not even set this. If you do, use the version for TclTk 8.5
in /usr/bin
> export GRASS_WISH=/usr/X11R6/bin/wish
This should be /usr/bin/wish8.5
> export VTK_DIR=/Users/elvis/Tool/vtk-5.2.0/src
> export VTK_LIB_DIR=/usr/local/lib/vtk-5.2
> export X11_LIB_DIR=/usr/X11/lib
If you are compiling with aqua, you don't need this.
> #export OPENGL_LIB_DIR=/Developer/SDKs/MacOSX10.5.sdk/System/Library/
> Frameworks/OpenGL.framework/Versions/A/Libraries
You won't need this (i.e., leave it commented out)
> # the path is initially set to "/usr/bin:/bin:/usr/sbin:/sbin:/usr/
> local/bin:/usr/X11/bin"
> export PATH=$PATH:$QTROOT/bin
> export LD_LIBRARY_PATH=$VTK_LIB_DIR:$X11_LIB_DIR:$LD_LIBRARY_PATH
> export DYLD_LIBRARY_PATH=$VTK_LIB_DIR:$X11_LIB_DIR:$DYLD_LIBRARY_PATH
> Best regards,
> Elvis Dowson
