[GRASS-user] Re: Problem cannot find grass-6.4.0 plug in in the
qgis-0.11.0 plugin settings
Elvis Dowson
elvis.dowson at mac.com
Mon Sep 22 06:14:34 EDT 2008
Ok found out the reason why. You need to explicitly specify the full
base path, within the application package as follows for GRASS_PREFIX
GRASS_PREFIX=/Applications/GRASS/GRASS-6.4.app/Contents/MacOS
GRASS_INCLUDE_DIR=/Applications/GRASS/GRASS-6.4.app/Contents/MacOS/
include
This builds the grass plugin just fine!! :-) Whew!!
On Sep 22, 2008, at 1:47 PM, Elvis Dowson wrote:
> Hi,
> I tried to rebuild qgis-0.11.0 with the following commands
> ccmake CMakeLists.txt
> and set the following options
> include
> WITH_GRASS=ON
> But still qgis doesnt detect the gdal-grass plugin. What should I do?
> Best regards,
> Elvis
> On Sep 22, 2008, at 1:28 PM, Elvis Dowson wrote:
>> Hi,
>> I found out that you have to first build gdal without grass
>> support, then build grass, and then download the gdal-grass plugin
>> and try to build it with grass.
>> This is outlined here: http://trac.osgeo.org/gdal/wiki/GRASS
>> I then type the following configure command
>> ./configure --with-gdal=/usr/local/bin/gdal-config --with-grass=/
>> And then it configures correctly!! :-)
>> Note that the libraries are located in /Applications/GRASS/
>> GRASS-6.4.app/Contents/MacOS/lib but you should just specify
>> Applications/GRASS/GRASS-6.4.app/Contents/MacOS (i.e. do not
>> explicitly specify the lib directory).
>> Best regards,
>> Elvis Dowson
>> On Sep 22, 2008, at 12:16 PM, Elvis Dowson wrote:
>>> Hi,
>>> I cannot seem to find the grass-6.4.0 plugin in qgis-0.11.0
>>> plugin preferences.
>>> Could you tell me where it is normally built and if I have to copy
>>> the grass-6.4.0 plugin into the qgis-0.11.0 plugin directory?
>>> Also, which compilation step builds the plugin? The grass-6.4.0 or
>>> the qgis-0.11.0 one?
>>> Best regards,
>>> Elvis Dowson
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080922/12fb45c7/attachment.html
