[GRASS-user] Re: Problem cannot find grass-6.4.0 plug in in the
	qgis-0.11.0 plugin settings
    William Kyngesburye
    woklist at kyngchaos.com
    Mon Sep 22 09:50:03 EDT 2008
It looks like you figured it out, but any further questions about
building Qgis should go to the Qgis list.
There is a wiki page at the Qgis site (duplicated in text form in the
Qgis source) with everything you need to know for building Qgis.
On Sep 22, 2008, at 5:14 AM, Elvis Dowson wrote:
> Ok found out the reason why. You need to explicitly specify the full
> base path, within the application package as follows for GRASS_PREFIX
> GRASS_PREFIX=/Applications/GRASS/GRASS-6.4.app/Contents/MacOS
> GRASS_INCLUDE_DIR=/Applications/GRASS/GRASS-6.4.app/Contents/MacOS/
> include
> This builds the grass plugin just fine!! :-) Whew!!
> On Sep 22, 2008, at 1:47 PM, Elvis Dowson wrote:
>> Hi,
>>          I tried to rebuild qgis-0.11.0 with the following commands
>> ccmake CMakeLists.txt
>> and set the following options
>> include
>> WITH_GRASS=ON
>> But still qgis doesnt detect the gdal-grass plugin. What should I do?
>> Best regards,
>> Elvis
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
The equator is so long, it could encircle the earth completely once.
