[GRASS-user] Re: Problem cannot find grass-6.4.0 plug in in the qgis-0.11.0 plugin settings
John C. Tull john.tull at wildnevada.org
Mon Sep 22 18:19:57 EDT 2008
On Sep 22, 2008, at 6:46 AM, William Kyngesburye wrote:
> On Sep 22, 2008, at 4:28 AM, Elvis Dowson wrote:
>> Hi,
>>      I found out that you have to first build gdal without grass
>> support, then build grass, and then download the gdal-grass plugin
>> and try to build it with grass.
>> This is outlined here: http://trac.osgeo.org/gdal/wiki/GRASS
>> I then type the following configure command
>> ./configure --with-gdal=/usr/local/bin/gdal-config --with-grass=/
>> Applications/GRASS/GRASS-6.4.app/Contents/MacOS
>> And then it configures correctly!! :-)
> Have you considered using my frameworks?  I make them so you don't
> have to mess around with this (and it doesn't matter that I use the
> stable GRASS 6.3 for GDAL - GRASS 6.4 doesn't care, and 6.3 has
> everything GDAL needs).
+1
