[GRASS-user] g.mremove error: "Argument list too long"
Rainer M Krug
r.m.krug at gmail.com
Wed Sep 24 10:50:04 EDT 2008
On Wed, Sep 24, 2008 at 4:01 PM, Daniel Victoria
<daniel.victoria at gmail.com> wrote:
> Hi,
> How about separating it in smaller chunks.
> Try 3 comands first
> g.mremove -f rast=*
> g.mremove -f vect=*
> g.mremove -f region=*
That would not help much - all (except of a handfull of layers) are raster
> If you still get "argument list to long" you will have to split the
> rast/vect/region list once more. I don't know how your rasters are
> named but, for example, remove all that starts with the letter a
> g.remove -f rast=a*
That would be an option - but as it is used in a simulation, I don't
know for sure that not to many starting with a are created.
I therefore resorted to iterate through them:
for I in `g.mlist type=rast`;do g.remove $I; done
But in general, I would consider it a bug if an operation with
wildcard results in an error when to many are selected. I will file a
bug report for that.
Thanks
Rainer
> or some other division
> Cheers
> Daniel
> On Wed, Sep 24, 2008 at 10:27 AM, Rainer M Krug <r.m.krug at gmail.com> wrote:
>> Hi
>> I am using GRASS for a simulation which generates litrealy thousands
>> of layers. Before I start a new simulation, I want to delete all
>> existing layers, and I run into th following error message:
>>> g.mremove -f rast=* vect=* region=*
>> Collecting map names for current mapset <simulation>...
>> Forcing ...
>> exec: 218: g.remove: Argument list too long
>> Is there anything I can do? except iterating through all layers and
>> deleting them separately?
>> And if no, How could I do this easily?
>> Thanks
>> Rainer
>> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
>> Biology, UCT), Dipl. Phys. (Germany)
>> Centre of Excellence for Invasion Biology
>> Faculty of Science
>> Natural Sciences Building
>> Private Bag X1
>> University of Stellenbosch
>> Matieland 7602
>> South Africa
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
Faculty of Science
Private Bag X1
Matieland 7602
South Africa
