[GRASS-user] g.mremove error: "Argument list too long"
Daniel Victoria
daniel.victoria at gmail.com
Wed Sep 24 10:01:38 EDT 2008
How about separating it in smaller chunks.
Try 3 comands first
g.mremove -f rast=*
g.mremove -f vect=*
g.mremove -f region=*
If you still get "argument list to long" you will have to split the
rast/vect/region list once more. I don't know how your rasters are
named but, for example, remove all that starts with the letter a
g.remove -f rast=a*
or some other division
Cheers
Daniel
On Wed, Sep 24, 2008 at 10:27 AM, Rainer M Krug <r.m.krug at gmail.com> wrote:
> Hi
> I am using GRASS for a simulation which generates litrealy thousands
> of layers. Before I start a new simulation, I want to delete all
> existing layers, and I run into th following error message:
>> g.mremove -f rast=* vect=* region=*
> Collecting map names for current mapset <simulation>...
> Forcing ...
> exec: 218: g.remove: Argument list too long
> Is there anything I can do? except iterating through all layers and
> deleting them separately?
> And if no, How could I do this easily?
> Thanks
> Rainer
> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
> Biology, UCT), Dipl. Phys. (Germany)
> Centre of Excellence for Invasion Biology
> Faculty of Science
> Natural Sciences Building
> Private Bag X1
> University of Stellenbosch
> Matieland 7602
> South Africa
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
