[GRASS-user] Re: grass-user Digest, Vol 29, Issue 56
    Michael Barton
    michael.barton at asu.edu
    Wed Sep 24 13:46:25 EDT 2008
On Sep 24, 2008, at 5:48 AM, <grass-user-request at lists.osgeo.org> wrote:
> Date: Wed, 24 Sep 2008 14:48:53 +0200
> From: "Edmondo Elisei" <edmondo.elisei at gmail.com>
> Subject: [GRASS-user] srtm data import
> To: grass-user at lists.osgeo.org
> Message-ID:
> 	<412a97fc0809240548g7c1d4b20o7c5becadc3eac121 at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> hi all,
> there someone that can help me about srtm CGIAR data importing into
> grass
> 6.3?
> Hi tryed by downloading data as GEOTIFF and I've imported in GRASS
> but the
> resultant map haven't  elevation, with ASCII GRID it happens the same
It happens that I just tried this with a student yesterday. It seems
that the new version 4 SRTM's from CGIAR do not have projection
information in the header. (Probably need to contact someone there
about this).
Anyway, the way to deal with this is to create a latlong region with a
WGS84 datum and use r.in.gdal to import the SRTM. IMPORTANT: you'll
need to set the projection override flag.
They should import fine in this way.
Michael
> Thanks in advance
> Regards
> Edmondo
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080924/d9d760a8/attachment.html
