[GRASS-user] problems : Display active layers in win grass63
    Moritz Lennert
    mlennert at club.worldonline.be
    Thu Sep 25 03:31:31 EDT 2008
On 25/09/08 03:39, Zahid Parvez wrote:
> Sir
>  > I have followed your advices
>  > I have encountered two problems  -
>     Prob.01- Can't able to show maps in wingrass63.
>     Following steps are followed
>     > Click the target bat file "C:\GRASS\grass63.bat -tcltk"
>     > Select from Projectlocation-Spearfish60
>     > Select from Accessible Mapsets-user1
>     > Select Enter Grass
>     > The Grass GIS manager 6.3.0 appears
>     > From Output GIS.m window d.m$ is runned in Xterm
No need to run d.m. This will not work in windows as it uses x-monitors
which are not support in windows.
Just use the first display manager that appears to display you map. If
you need some info on how to use that, see the man page of 'gis.m'.
Moritz
