[GRASS-user] GRASS GIS
    Zahid Parvez
    grassgisbangladesh at gmail.com
    Sun Sep 28 14:05:03 EDT 2008
Dear Grass users
Software: windows **native Grass 63** and **spearfish 60** data
Problem:  facing problem in "**v.in.ogr**" command.
Description:
>>> Successfully started GRASS GIS and  spearfish data loaded.
>>> First opened File -> Import -> Vector map -> Multiple formats using OGR.
>>> v.in.ogr window appears
>>> First Parameter needed is "path to the shape file (OGR data source
name)"
   Suppose my shape file data is in location "C:\world_factbk"
   So I have given the path  C:\world_factbk in OGR Datasource name box.
>>> name of the vector map to be created (Name of output vector map): worlds
>>> name of the file shp to be imported (OGR layer name), without
extension:
world_factbk
>>> Override projection is check box is clicked.
>>> RUN is clicked
Output in GIS.m window:
ERROR: Unable to open data source <C:/world_factbk/world_factbk>
I wander what will be its solution
Sincerely yours
Md.Zahid Parvez
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080929/651dfb2e/attachment.html
