[GRASS-user] GRASS GIS
Maris Nartiss maris.gis at gmail.com
Mon Sep 29 07:28:37 EDT 2008
Hello,
at first - when reporting a problem, please include full command with
all of it's parameters. Use copy/paste to transfer also all typos You
may have.
Second - double check that there is a file named
C:/world_factbk/world_factbk and You can read it. I suppose You have
read manual where shapefile import example is given. And if You use
projection override option, are Your data in same projection as
current location?
Documentation is Your friend.
Maris.
2008/9/28 Zahid Parvez <grassgisbangladesh at gmail.com>:
> Dear Grass users
> Software: windows *native Grass 63* and *spearfish 60* data
> Problem:  facing problem in "*v.in.ogr*" command.
> Description:
>>>> Successfully started GRASS GIS and  spearfish data loaded.
>>>> First opened File -> Import -> Vector map -> Multiple formats using OGR.
>>>> v.in.ogr window appears
>>>> First Parameter needed is "path to the shape file (OGR data source
> name)"
>    Suppose my shape file data is in location "C:\world_factbk"
>    So I have given the path  C:\world_factbk in OGR Datasource name box.
>>>> name of the vector map to be created (Name of output vector map): worlds
>>>> name of the file shp to be imported (OGR layer name), without
> extension:
> world_factbk
>>>> Override projection is check box is clicked.
>>>> RUN is clicked
> Output in GIS.m window:
> ERROR: Unable to open data source <C:/world_factbk/world_factbk>
> I wander what will be its solution
> Sincerely yours
> Md.Zahid Parvez
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
