[GRASS-user] Re: Problem grass-6.4.0 error setting region: child process exited abnormally
Elvis Dowson elvis.dowson at mac.com
Mon Sep 29 17:18:22 EDT 2008
         I built grass-6.4.0 using the following configure command:
./configure --with-cxx --prefix=/Applications/GRASS --enable-macosx-
app --with-x --with-opengl=x11 --without-readline --x-includes=/usr/
X11/include --x-libraries=/usr/X11/lib --with-opengl-includes=/usr/X11/
include --with-opengl-libs=/usr/X11/lib
Does this have something to do with me not starting the X11 display
server? How do I do this on Mac OS X?
Is there a way to get grass to compile with Carbon bindings?
Best regards,
Elvis Dowson
On Sep 30, 2008, at 1:15 AM, Elvis Dowson wrote:
> Hi,
>         I'm getting some errors when trying to use some basic
> grass-6.4.0 operations.
> I click on Add a Raster Layer and select the aspect file from the
> spearfish60 permanent dataset.
> After that I click on Display Active Layers and I get an error
> message "Error setting region: child process exited abnormally"
> <pastedGraphic.png>
> After that I get an error message saying" Error can't read
> parts(projection)": no such variable
> <pastedGraphic.png>
> If I click on the details button, I get the following error
> information:
> can't read "parts(projection)": no such variable
>    while executing
> "regexp -nocase {^([0-9]+)} $parts(projection) trash
> parts(projection)"
>    (procedure "MapCanvas::runprograms" line 46)
>    invoked from within
> "MapCanvas::runprograms $mon [expr {$mymodified != 0}]"
>    (procedure "MapCanvas::drawmap" line 38)
>    invoked from within
> "MapCanvas::drawmap $mon"
>    (procedure "MapCanvas::display_server" line 9)
>    invoked from within
>    ("after" script)
> What could be causing it?  I just built grass-6.4.0 on Mac OS X
> 10.5.5.
> Best regards,
> Elvis Dowson
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080930/31c657f8/attachment.html
