[GRASS-user] Re: Problem grass-6.4.0 error setting region: child
	process exited abnormally
    Glynn Clements
    glynn at gclements.plus.com
    Mon Sep 29 20:14:18 EDT 2008
Elvis Dowson wrote:
> > I click on Add a Raster Layer and select the aspect file from the
> > spearfish60 permanent dataset.
> > After that I click on Display Active Layers and I get an error
> > message "Error setting region: child process exited abnormally"
> > <pastedGraphic.png>
> > After that I get an error message saying" Error can't read
> > parts(projection)": no such variable
> > What could be causing it?
99.9% of the time, this error is related to the GDAL library.
If you start GRASS in text mode then run "g.region -p", you may get a
more informative error message.
