[GRASS-user] Re: Problem grass-6.4.0 error setting region: child
	process exited abnormally
    Elvis Dowson
    elvis.dowson at mac.com
    Tue Sep 30 01:05:59 EDT 2008
Hi Glynn,
                     Running this command yeilds the following output:
GRASS 6.4.svn (spearfish60):~ > g.region -p
projection: 1 (UTM)
zone:       13
datum:      nad27
ellipsoid:  clark66
north:      4928010
south:      4913700
west:       589980
east:       609000
nsres:      150.63157895
ewres:      149.76377953
rows:       95
cols:       127
cells:      12065
Best regards,
Elvis Dowson
On Sep 30, 2008, at 4:14 AM, Glynn Clements wrote:
> Elvis Dowson wrote:
>>> I click on Add a Raster Layer and select the aspect file from the
>>> spearfish60 permanent dataset.
>>> After that I click on Display Active Layers and I get an error
>>> message "Error setting region: child process exited abnormally"
>>> <pastedGraphic.png>
>>> After that I get an error message saying" Error can't read
>>> parts(projection)": no such variable
>>> What could be causing it?
> 99.9% of the time, this error is related to the GDAL library.
> If you start GRASS in text mode then run "g.region -p", you may get a
> more informative error message.
> Glynn Clements <glynn at gclements.plus.com>
