[GRASS-user] Re: GRASS-user] Re: Problem grass-6.4.0 error setting region: child process exited abnormally
William Kyngesburye woklist at kyngchaos.com
Tue Sep 30 10:19:57 EDT 2008
On Sep 29, 2008, at 11:30 PM, Michael Barton wrote:
> One guess as to why you are getting a TclTk GUI even when you
> compile without it. You probably compiled with it, which put all the
> TclTk scripts into your binary grass.app file. If you subsequently
> compile without it and do a "make install", it will put in new files
> and overwrite old files with new, but will not get rid of files not
> overwritten. That is, you probably still have the TclTk scripts in
> your grass.app folder. They are simply text files that are
> interpreted as they are run. So you aren't actually compiling them,
> but simply copying them from the source tree into your binary
> grass.app folder. So they are still there, even after you have
> compiled without them unless you delete your grass.app and have a
> new one built from scratch.
Actually, I think the tcltk scripts are installed unconditionally.
The --with-tcltk option is for compiling the nviz binary.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
The equator is so long, it could encircle the earth completely once.
