[GRASS-user] Re: Patched version of libjpeg-6b for 32-bit and
64-bit architectures
Elvis Dowson
elvis.dowson at mac.com
Tue Sep 30 17:44:43 EDT 2008
Hi Sean,
I didn't check the internal version that vtk uses.
The thing is, you need an external version of libjpeg when compiling
for grass-6.4.0.
libjpeg-6b was released in 1998! I also came across many references to
problems others have faced when attempting to compile it for 64-bits.
On the first go, I too had problems. Since I had to do some major
learning and get things working in atleast 32-bits, I put it off for a
while. Now that I have a 32-bit environment working, I thought Id try
to fix some of the outstanding issues, libjpeg 64-bits being one of
them! :-)
Here is the link to the website: Independent JPEG Group
I also came across a set of patches in another website, and then
applied it and somehow got it to work.
So I thought I'd share it with the group!
Best regards,
Elvis Dowson
On Oct 1, 2008, at 1:35 AM, Sean McBride wrote:
> On 10/1/08 12:58 AM, Elvis Dowson said:
>> One of the things that took a long time to fix was libjpeg-6b
>> support for 64-bit.
> No doubt the version of libjpeg that VTK includes in years old (as is
> the case for much of VTK's 3rd party source). Did you check which
> version VTK uses? Who maintains libjpeg-6b? Maybe their newest
> version
> is 64bit clean?
> ____________________________________________________________
> Sean McBride, B. Eng sean at rogue-research.com
> Rogue Research www.rogue-research.com
> Mac Software Developer Montréal, Québec, Canada
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20081001/9a55ff76/attachment.html
