[GRASS-user] error in r.fillnull
    Markus Neteler
    neteler at osgeo.org
    Wed Apr  1 08:37:28 EDT 2009
On Wed, Apr 1, 2009 at 1:52 PM, Glynn Clements <glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> >> Found the same in v.centroids, both fixed in 6.4.svn, 6.5, and 7.
>> >> Thanks for reporting it,
>> > Someone should file a bug report along the lines of "v.info lacks a -g
>> > switch".
>> Are you aware of any remaining problems? I check all scripts with
>> grep and didn't find more.
> The problem is that v.info doesn't have an option to produce
> machine-readable output. The -t switch doesn't cover all of the
> information which v.info can output.
Ok, got the point now, thanks.
Reported as
http://trac.osgeo.org/grass/ticket/544
I took liberty to cite your explanations.
Markus
