[GRASS-user] import DWG files ?
Martin Landa landa.martin at gmail.com
Wed Apr 1 12:35:00 EDT 2009
2009/4/1 Grégoire Pigeon <gregoire.pigeon at meteo.fr>:
> is it still possible to import dwg files in grass6.2.3
> I remember that I did that with grass6.0.1 and the OpenAlliance library.
should be possible (you need to compile v.in.dwg). Anyway I would
recommend you to use documented formats instead of DWG. Also consider
updating to GRASS 6.4.0.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
