[GRASS-user] concurrent versions of grass
Markus Neteler neteler at osgeo.org
Wed Apr 1 16:53:11 EDT 2009
Unless you don't use GEM then you are fine to remove/rename it.
Markus
On Wed, Apr 1, 2009 at 10:33 PM, Vincent Bain <bain at toraval.fr> wrote:
> In my case, what if I voluntarily remove gem6 before installing a second
> version of Grass ? will the previous grass install be damaged ?
> Le mercredi 01 avril 2009 à 22:28 +0200, Markus Neteler a écrit :
>> On Wed, Apr 1, 2009 at 10:24 PM, Vincent Bain <bain at toraval.fr> wrote:
>> > Perhaps,
>> > but it could be interesting to check whether the error is reproductible,
>> Yes: because in all GRASS 6 versions it is called gem6 (unfortunately).
>> So it must conflict...
>> If the others agree I'll start to add the second version number starting
>> with GRASS 6.5. Then behaviour doesn't change for 6.4.
>> Markus
