[GRASS-user] concurrent versions of grass
Hamish hamish_b at yahoo.com
Wed Apr 1 21:09:27 EDT 2009
> [/usr/bin/gem6]
> (does it need to be in the main PATH at all? even if it is
> meanto to be
> used outside of a grass session)
> Markus wrote:
> > If the others agree I'll start to add the second
> > version number starting with GRASS 6.5.
> sounds good.
> > Then behaviour doesn't change for 6.4.
> rename to gem[MAJOR][MINOR] with a symlink back to "gem6"?
> is backwards compatibility needed here? if new is gem64 it
> will not
> collide with earlier versions.
> Hamish
