[GRASS-user] problems with i.rectify
Martina Schäfer
Martina.Schafer at ebc.uu.se
Fri Apr 3 04:46:55 EDT 2009
Hi again!
I installed GRASS 6.4 and first I got the same error. Then, I tried with
defining a new group and subgroup in the XY mapset (not using the one
that is created when importing) and with that it worked!! However, I
also tried using wxpython, which looks neat, but there I get the error
message that the group does not exist (but it certainly does).
Best,
Martina
Markus Neteler skrev:
> hi Martina,
> On Thu, Apr 2, 2009 at 9:28 AM, Martina Schäfer
> <Martina.Schafer at ebc.uu.se> wrote:
>> Hello Markus,
>> thanks for the reply! And thanks for the tip on i.orto.photo, I will read
>> through your article!
>>>> I've followed the instructions
>>>> and everything's working fine except that the red band is not included.
>>>> In
>>>> the output it says :
>>>> Rectified input file NN1_2.red will be saved as NN1_2.red 1257
>>> I see a suspicious white space before 1257.
>>> Where does it come from? Could it be that it crept
>>> in when defining the group?
>> Well, the space was my fault and a typing mistake, it really says
>> NN1_2.red1257, so no error there.
> ah ok, perfect.
>>> In the mapset there is a group/ directory in which the
>>> group is defined (ASCII file). The easiest way is to check
>>> there/fix if the red channel was defined properly.
>> I looked in the group folder and found a file REF where all bands are
>> properly named. Was that the file you meant?
> Yes, fine.
>> The group is defined in the XY location. In the projected location it does
>> not exist prior to rectifying.
>>> BTW: which GRASS version and which operating system?
>> I'm using GRASS 6.3. downloaded from http://grass.bologna.enea.it/ on Mac OS
>> X 10.5.6
> I recall that we fixed some issues later. Could you upgrade to 6.4RC3
> instead?
> http://grass.osgeo.org/download/index.php#g64x
> If it still fails we may be able to fix it for 6.4.0 final.
> best
> Markus
