[GRASS-user] problems with i.rectify
Martina Schäfer Martina.Schafer at ebc.uu.se
Mon Apr 6 02:46:20 EDT 2009
Hi ,
just want to add that when I rectified the next image the same error
appeared again - the first band in the group is not rectified as it is
"not found".  I lured the programme now by adding an additional band
from a similar image to the group and put it in first place , so that
this band is not rectified/found but the three bands of my image are...
regards,
Martina
Martina Schäfer skrev:
> Hi again!
> I installed GRASS 6.4 and first I got the same error. Then, I tried
> with defining a new group and subgroup in the XY mapset (not using the
> one that is created when importing) and with that it worked!! However,
> I also tried using wxpython, which looks neat, but there I get the
> error message that the group does not exist (but it certainly does).
> Best,
> Martina
> Markus Neteler skrev:
>> hi Martina,
>> On Thu, Apr 2, 2009 at 9:28 AM, Martina Schäfer
>> <Martina.Schafer at ebc.uu.se> wrote:
>>> Hello Markus,
>>> thanks for the reply! And thanks for the tip on i.orto.photo, I will
>>> read
>>> through your article!
>>>>> I've followed the instructions
>>>>> and everything's working fine except that the red band is not
>>>>> included.
>>>>> In
>>>>> the output it says :
>>>>> Rectified input file NN1_2.red will be saved as NN1_2.red 1257
>>>> I see a suspicious white space before 1257.
>>>> Where does it come from? Could it be that it crept
>>>> in when defining the group?
>>> Well, the space was my fault and a typing mistake, it really says
>>> NN1_2.red1257, so no error there.
>> ah ok, perfect.
>>>> In the mapset there is a group/ directory in which the
>>>> group is defined (ASCII file). The easiest way is to check
>>>> there/fix if the red channel was defined properly.
>>> I looked in the group folder and found a file REF where all bands are
>>> properly named. Was that the file you meant?
>> Yes, fine.
>>> The group is defined in the XY location. In the projected location
>>> it does
>>> not exist prior to rectifying.
>>>> BTW: which GRASS version and which operating system?
>>> I'm using GRASS 6.3. downloaded from http://grass.bologna.enea.it/
>>> on Mac OS
>>> X 10.5.6
>> I recall that we fixed some issues later. Could you upgrade to 6.4RC3
>> instead?
>> http://grass.osgeo.org/download/index.php#g64x
>> If it still fails we may be able to fix it for 6.4.0 final.
>> best
>> Markus
