[GRASS-user] errors in r.drain (develbranch)
    Carlos "Guâno" Grohmann
    carlos.grohmann at gmail.com
    Mon Apr  6 16:33:39 EDT 2009
>> Errors in:
>> /home/guano/pessoal/tmp_install/gis/grass6_devel/raster/r.drain
> (that's indeed grass7_devel/raster/r.drain/, right?)
It's develbranch 6 (GRASS 6.5)
svn checkout https://svn.osgeo.org/grass/grass/branches/develbranch_6
grass6_devel
>> guano[grass6_devel]$ cd raster/r.drain/
>> guano[r.drain]$ make
>> gcc -I/home/guano/pessoal/tmp_install/gis/grass6_devel/dist.i686-pc-linux-gnu/include
>>  -mt
>> une=nocona -minline-all-stringops -O2 -Wall -D_FILE_OFFSET_BITS=64
>> -I/usr/include/gdal
>>   -DPACKAGE=\""grassmods"\"
>> -pc-linux-gnu/include -o OBJ.i686-pc-linux-gnu/main.o -c main.c
>> main.c: In function ‘main’:
>> main.c:174: warning: format not a string literal and no format arguments
> that line reads
>                G_warning(_("Starting point %d is outside the current region"),
> in GRASS 7.
> I assume that you lost somehow --with-nls as configure parameter so that
> the gettext macro isn't recognised completely.
--with-nls is there (from ./configure):
checking whether to use NLS... yes
checking for gettext... yes
> I suggest a "make distclean" and new configure.
This is a fresh download..
Carlos
Carlos Henrique Grohmann - Geologist D.Sc.
a.k.a. Guano - Linux User #89721
ResearcherID: A-9030-2008
carlos dot grohmann at gmail dot com
http://www.igc.usp.br/pessoais/guano/
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
Can’t stop the signal.
