[GRASS-user] errors in r.drain (develbranch)
Colin Nielsen colin.nielsen at gmail.com
Mon Apr 6 19:19:32 EDT 2009
This might be an error with my updates
(http://trac.osgeo.org/grass/changeset/36351). I'm not sure why there
wasn't any error reported for me or others, but I see that there is an
inconsistency in the code (my addition at 387 compared to lines 373
and 374).
387 	        dir_fd = open(tempfile3, O_RDWR | O_CREAT);
Should be:
387 	        dir_fd = open(tempfile3, O_RDWR | O_CREAT, 0666);
Trying making that change and recompile. Markus, I can submit a diff
for this line if needed.
-Colin
2009/4/6 Carlos "Guâno" Grohmann <carlos.grohmann at gmail.com>:
>>> Errors in:
>>> /home/guano/pessoal/tmp_install/gis/grass6_devel/raster/r.drain
>> (that's indeed grass7_devel/raster/r.drain/, right?)
> It's develbranch 6 (GRASS 6.5)
> svn checkout https://svn.osgeo.org/grass/grass/branches/develbranch_6
> grass6_devel
>>> guano[grass6_devel]$ cd raster/r.drain/
>>> guano[r.drain]$ make
>>> gcc -I/home/guano/pessoal/tmp_install/gis/grass6_devel/dist.i686-pc-linux-gnu/include
>>>  -mt
>>> une=nocona -minline-all-stringops -O2 -Wall -D_FILE_OFFSET_BITS=64
>>> -I/usr/include/gdal
>>>   -DPACKAGE=\""grassmods"\"
>>> -pc-linux-gnu/include -o OBJ.i686-pc-linux-gnu/main.o -c main.c
>>> main.c: In function ‘main’:
>>> main.c:174: warning: format not a string literal and no format arguments
>> that line reads
>>                G_warning(_("Starting point %d is outside the current region"),
>> in GRASS 7.
>> I assume that you lost somehow --with-nls as configure parameter so that
>> the gettext macro isn't recognised completely.
> --with-nls is there (from ./configure):
> checking whether to use NLS... yes
> checking for gettext... yes
>> I suggest a "make distclean" and new configure.
> This is a fresh download..
> Carlos
> Carlos Henrique Grohmann - Geologist D.Sc.
> a.k.a. Guano - Linux User #89721
> ResearcherID: A-9030-2008
> carlos dot grohmann at gmail dot com
> http://www.igc.usp.br/pessoais/guano/
> _________________
> "Good morning, doctors. I have taken the liberty of removing Windows
> 95 from my hard drive."
> --The winning entry in a "What were HAL's first words" contest judged
> by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
> Can’t stop the signal.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
