[GRASS-user] working on a mounted external disk
Moritz Lennert
mlennert at club.worldonline.be
Wed Apr 8 04:48:34 EDT 2009
On 08/04/09 10:31, Vincent Bain wrote:
> Hello,
> has anybody ever had problems accessing a gisdbase located on an
> external disk ? In my case, I can open a grass session in a distant
> location/mapset :
> grass65 /mnt/path_to_my_disk/my_location/topo
>>From within this place, everything works well, OK.
> If I start grass from my home directory and try to reproject data from
> the distant directory :
> grass65 /home/vincent/my_gisdbase/my_location/my_mapset
> r.proj input=dem50 location=/mnt/path_to_my_disk/my_location
> mapset=topo output=dem50
> Then an error occurs :
> ERREUR :Mapset <topo> in input location
> </mnt/path_to_my_disk/my_location/> - not found
> whereas the disk is properly mounted there and accessible...
> Any idea on why grass seems not to see the mounted directory ?
You need to use the dbase= option of r.proj to direct it to another
database. In your case it is looking for a location called
"/mnt/path_to_my_disk/my_location/" in your current gisdatabase.
Moritz
