[GRASS-user] working on a mounted external disk
    Vincent Bain
    bain at toraval.fr
    Wed Apr  8 05:51:05 EDT 2009
Thank you Moritz,
I tried to specify the path to the target database location this way :
        r.proj input=dem50 location=/mnt/path_to_my_disk/my_location
        mapset=topo dbase=/mnt/path_to_my_disk/ output=dem50
unfortunately it still returns the same error.
Well, maybe I should change the title of this post, because I notice now
that the problem is the same with "resident" paths on the machine
(apparently nothing to deal with mounted directory).
Vincent
Le mercredi 08 avril 2009 à 10:48 +0200, Moritz Lennert a écrit :
> You need to use the dbase= option of r.proj to direct it to another
> database. In your case it is looking for a location called
> "/mnt/path_to_my_disk/my_location/" in your current gisdatabase.
> Moritz
