[GRASS-user] Moving GISBASE box2box
Cassiel raffaele.morelli at gmail.com
Wed Apr 8 08:10:52 EDT 2009
2009/4/8 Moritz Lennert <mlennert at club.worldonline.be>
> On 08/04/09 13:58, Cassiel wrote:
>> Hi you all,
>> I am having troubles in moving my GISBASE dir between two linux boxes.
>> At grass startup, once I select the gisbase dir, every mapset I try to
>> access results in this error message "this is not a valid mapset".
> I would guess that this might be a permissions issue. How did you move your
> dirs ?
> Moritz
I moved using a removable hd.
Permissions are ok... I also tried a chmod -R 777 (desperate isn't it?) but
didn't worked.
Could it be a locale mismatch?
regards
r
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090408/75857280/attachment.html
