[GRASS-user] Moving GISBASE box2box
Massimiliano Cannata massimiliano.cannata at supsi.ch
Wed Apr 8 11:30:35 EDT 2009
Check the WINDOW file, and the owner...
Maxi
Cassiel wrote:
> 2009/4/8 Moritz Lennert <mlennert at club.worldonline.be
> <mailto:mlennert at club.worldonline.be>>
>     On 08/04/09 13:58, Cassiel wrote:
>         Hi you all,
>         I am having troubles in moving my GISBASE dir between two
>         linux boxes.
>         At grass startup, once I select the gisbase dir, every mapset
>         I try to access results in this error message "this is not a
>         valid mapset".
>     I would guess that this might be a permissions issue. How did you
>     move your dirs ?
>     Moritz
> I moved using a removable hd.
> Permissions are ok... I also tried a chmod -R 777 (desperate isn't
> it?) but didn't worked.
> Could it be a locale mismatch?
> regards
> r
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
