[GRASS-user] exporting areas to shapefiles without filling holes
    Moskovitz, Bob
    Bob.Moskovitz at conservation.ca.gov
    Thu Apr  9 13:05:44 EDT 2009
Hello Hamish,
I had a possibly related problem with a vector that went through v.clean.  I filed this ticket:  http://trac.osgeo.org/grass/ticket/397.
I noticed that layer 0 had the filled holes while layer 1 was the good polygons.  v.clean seemed to merge those two layers.  With Markus M's fix, I solved my problem.  Which reminds me...should I close this ticket since it works for me?
Bob
Bob Moskovitz
Research Analyst I
Seismic Hazard Evaluation Project
California Geological Survey
http://gmw.consrv.ca.gov/shmp
CONFIDENTIALITY NOTICE: This communication is intended only for the use of the individual or entity to which it is addressed. This message contains information from the State of California, California Geological Survey, which may be privileged, confidential and exempt from disclosure under applicable law, including the Electronic Communications Privacy Act. If the reader of this communication is not the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication is strictly prohibited.
> -----Original Message-----
> From: grass-user-bounces at lists.osgeo.org
> [mailto:grass-user-bounces at lists.osgeo.org]On Behalf Of Hamish
> Sent: Thursday, April 09, 2009 12:02 AM
> To: grass list
> Subject: [GRASS-user] exporting areas to shapefiles without filling
> holes
> Hi,
> I've got a grass vector map containing some areas with holes. It's a
> polygon of a river containing some islands; it looks nice in grass,
> centroids with cat in the wet parts, no centroids in the islands.
> There is no DB table.
> after exporting with 'v.out.ogr type=area' to a shapefile, when I load
> the shp file into QGIS 0.8.1 I see that all the holes have
> been filled in.
> The boundaries are still intact. using qgis's editing tools I can cut
> them out, but it takes a bit of manual labour to fix them all.
> what am I doing wrong?
> thanks,
> Hamish
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
