[GRASS-user] exporting areas to shapefiles without filling holes
Markus Metz markus.metz.giswork at googlemail.com
Thu Apr 9 03:33:33 EDT 2009
Hamish wrote:
> Hi,
> I've got a grass vector map containing some areas with holes. It's a
> polygon of a river containing some islands; it looks nice in grass,
> centroids with cat in the wet parts, no centroids in the islands.
> There is no DB table.
> after exporting with 'v.out.ogr type=area' to a shapefile, when I load
> the shp file into QGIS 0.8.1 I see that all the holes have been filled in.
> The boundaries are still intact. using qgis's editing tools I can cut
> them out, but it takes a bit of manual labour to fix them all.
> what am I doing wrong?
Maybe use v.out.ogr -c?
I did a quick test and got the same result like you, islands within
rivers are filled without -c. Exporting only features with a category
fixed it for me, holes stay holes and are not filled.
Best,
Markus M
