[GRASS-user] Problem with "location wizard tool" with wxPython GUI:
Jhon Ortiz
eljhonjhon at hotmail.com
Fri Apr 10 11:36:52 EDT 2009
Hi all,
Im working with GRASS.6.4.0RC3 in Ubuntu Hardy.
I tried to define a new GRASS location with "location wizard tool" with the new wxPython GUI:
I choose projection code: ll = Lat/Lon
And select datum with associated ellipsoid, Datum code = wgs84
But when I check my datum with g.proj -d got me this message:
GRASS 6.4.0RC3 (Mamonal_WGS84):~ > g.proj -d
Datum name not present
Datum parameters not present
Then I tried with others Datum code and it gave me the same problem.
I think, maybe is a "location wizard tool" problem in wxPython GUI, because I tried in the same
installation, but with Tcl/Tk GUI "projection values tool"
in the option coordinate system for location, I choose option B = Latitude-Longitude
and the option specify datum name, I type wgs84 and for this method is working Ok,
GRASS datum code: wgs84
WKT Name: WGS_1984
Datum transformation parameters (PROJ.4 format):
towgs84=0.000,0.000,0.000
Now I solved my problem with tcl/tk GUI, but my question is if somebody have been the same problem?
or do you think is a problem with my installation?
Thanks!!
John Ortiz
Bioestratigraphy Team - ICP
Bogotá Colombia
_________________________________________________________________
Más rápido, sencillo y seguro. Descárgate ya el nuevo Internet Explorer 8 ¡Es gratis!
http://www.vivelive.com/ie8
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090410/1d81c2b9/attachment-0001.html
