[GRASS-user] Multiple to one question
    Vincent Bain
    bain at toraval.fr
    Tue Apr 14 02:37:48 EDT 2009
Hello Adam,
maybe another solution in this case would be a set of 2 tables :
* one linking to the geometry, that is containing nothing but cat
values,
* another one, containing a cat column (related to the "geometric"
table) and different data columns corresponding to your sampling.
Does this help ?
VB
Le lundi 13 avril 2009 à 14:23 -0700, Adam Dershowitz a écrit :
> I am trying to set up a new project in Grass, and I have a question
> about the best approach.
> I have different vector locations, and at each one there were multiple
> samples taken.  At the moment I have each sample as a row in a data
> base.
> My question is how best to put this data into a set of vector points.
> I believe that I can do it in either of two ways (of not others).
> 1)  I can create a vector point at each location, then I think that I
> can have multiple cats for that object.  So I think I can do cat=1,3,6
> for a given location.
> Will that work OK?
> 2)  I can just create different vector objects, that happen to be at
> the identical location, and have each one point to a different cat.
> If the above is not clear, here is a bit more detailed example.
> At location A there was a sample collected on 1/1 with a value of 2.1,
> on 2/2 with a value of 2.2 and on 3/3 with a value of 3.3
> The above data is already 3 rows in a database.
> I want to be able to display data about point A (say, average value or
> things like that).  Should I just create a vector point A and then do
> cat=1,2,3 or should I create 3 different vector points at A, each one
> having a different cat?
> Any guidance about the benefits or limitations each approach (or any
> other approach to consider) would be greatly appreciated.
> Thanks,
> --Adam
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
