[GRASS-user] Rotate a map display
Vincent Bain bain at toraval.fr
Wed Apr 15 13:28:05 EDT 2009
Jérôme,
If you need to warp a map for a strict display purpose, IMHO it's not to
be performed from within grass given that this operation makes no sense
"geographically". Don't know what the context is, but if you just have
to rotate an image output of a map maybe you'd better look towards image
manipulation tools (e.g. imagemagick and the -rotate option, which can
easily be integrated in a script process).
Let us know a bit more about your needs !
Vincent
Le mercredi 15 avril 2009 à 10:22 +0200, Jérôme - GeoRezo.net a écrit :
> Hello,
> I want to make a map which follow a mobile. So I will have a set of raster maps
> and a polyline which represent a the path. One main feature is that map could
> follow the mobile's route.
> The y-axis could be the mobile'direction. My question is how can I do this.
> Best regards,
