[GRASS-user] m.eigensystem segfaults under Jaunty (beta)
    Nikos Alexandris
    nikos.alexandris at felis.uni-freiburg.de
    Sat Apr 18 05:20:04 EDT 2009
Nikos:
> > m.eigensystem, compiled against latest grass6_dev _AND_
> > grass-6.4.0RC4 source code, segfaults under Ubuntu-J 64-bit
> > Beta.
> > It works fine with Ubuntu Intrepid! So, something in Jaunty
> > doesn't like m.eigensystem (fortran code?)!
Hamish:
> > > > any chance of debugging? (gdb, etc)
> > > > how far does it get?
Hamish:
> perhaps you could compile into the fortran code some informative
> hints, e.g. put scatter some of these before and after reading
> the input values, etc:
> ----8<----
>        PRINT *,"Made it past normalizing the data"
> ----8<----
> (you have recompiled everything from scratch since the upgrade,
> right? ie you don't have any binaries trying to access library
> adresses which have since changed)
OK, maybe I'll try that also. Yes, everything from scratch -- not a
single binary...
...wait, there is FWTools. but this shouldn't have any influence in
grass' source code compilation, right?
Nikos
