[GRASS-user] m.eigensystem segfaults under Jaunty (beta)
hamish_b at yahoo.com
Fri Apr 17 21:55:20 EDT 2009
> Nikos:
> m.eigensystem, compiled against latest grass6_dev _AND_
> grass-6.4.0RC4 source code, segfaults under Ubuntu-J 64-bit
> Beta.
> It works fine with Ubuntu Intrepid! So, something in Jaunty
> doesn't like m.eigensystem (fortran code?)!
> Hamish:
> > > any chance of debugging? (gdb, etc)
> > > how far does it get?
perhaps you could compile into the fortran code some informative
hints, e.g. put scatter some of these before and after reading
the input values, etc:
----8<----
PRINT *,"Made it past normalizing the data"
----8<----
(you have recompiled everything from scratch since the upgrade,
right? ie you don't have any binaries trying to access library
adresses which have since changed)
Hamish
